I am using the new power teminal block 1492-LD16 which enable us to jump multiple terminal together.
How can I make understand Autocad that a jump terminal is now see as being 2 terminal.
Example a Feed trough terminal (1492-Ld16) that jump a 24VDC to a 1492-L3 will be able to feed 4 times
a 24VDC signal.
Is it possible to add 2 times the same terminal on different drawing but not using the same side of the terminal.
