With parametric PLCs, the terminal numbers and input terminal tags overlay each other when the PLC is inserted. Since these two numbers are the same, I'd like to set the input terminal tags to invisible for all future parametric PLCs I insert. Is there a way to do this? Also, is there a way to do this for all the parametric PLCs I've already inserted, project-wide?
I don't know of a truly easy way to do it. However, I do use the hide muliple attributes tool on existing drawings.
As for future drawings, I have been known to go into the symbol library and modify all of the symbols to meet a companies specific needs, like hiding some attributes. It is time consuming and if you are not careful to keep your modified symbols separate, when you upgrade ACADE you can lose all of the changes you made.
