AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
3D in autodesk electrical
2 REPLIES 2
Falcon1208
664 Views, 2 Replies
I'm an electrotechnic teacher, I downloaded and installed Autodesk Electrical because I would like to show nice 3D house circuit like that to my students :
How can I proceed to build such thing  ?
Eric.
2 REPLIES 2
Wheelie22
in reply to: Falcon1208
Did not know that !
acadE - help - 3d :
In this half of the tutorial, you learn how to export your data from AutoCAD
Electrical to Inventor. The sample DWG file is a wiring diagram used for a seat
assembly. The assembly uses electric motors to provide adjustments to the seat
position.
So that picture is made by Inventor !
Eric, Autodesk Inventor Professional is the correct product to illustrate in a 3D format.  AutoCAD Electrical can provide the data as an XML export to Inventor Pro.  The wire from/to data and the bill of material can both be exported.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
”Boost
