I'm an electrotechnic teacher, I downloaded and installed Autodesk Electrical because I would like to show nice 3D house circuit like that to my students :
How can I proceed to build such thing ?
Eric.
Did not know that !
acadE - help - 3d :
In this half of the tutorial, you learn how to export your data from AutoCAD
Electrical to Inventor. The sample DWG file is a wiring diagram used for a seat
assembly. The assembly uses electric motors to provide adjustments to the seat
position.
So that picture is made by Inventor !
Eric, Autodesk Inventor Professional is the correct product to illustrate in a 3D format. AutoCAD Electrical can provide the data as an XML export to Inventor Pro. The wire from/to data and the bill of material can both be exported.
