Please try setting this up as the first two pins under the COILPINS column
and remaining under the PINLIST column. i.e, 1,2 under the coil pins column
and 1,3,4;1,5,6;1,13,14;2,21,22 in the PINLIST. This is beacuse when the
three pole is inserted the first one is the Parent and the second two are
considered children.
Hope this helps.
Giri.
wrote in message news:5164912@discussion.autodesk.com...
Extra info on previous post. A view on the settings.
