Can you submit an example of how you use the 3 phase wire number tool and what the results look like? I am still creating my 3 phase wire numbers manually. I would like to find a method to automatically generate the wire numbers.
I have used the layer override in the wire numbering tool.
I have 5 layers for each type of the most common 3 phase circuits that we use.
For example layers,
Red Primary Protection CT
White Primary Protection CT
Blue Primary Protection CT
Black Primary Protection CT
Earth Primary Protection CT
These are used for CT's that are connected to primary protection devices. Local regulations have thes with a prefix of A and numbered 10 to 29 for Red, 30-49 for White, 50 to 69 for Blue, 70 to 89 for Black and 90 for the earth.
So a set of wire numbers from the CT would be A10, A30,A50,A70 AND A90.
In the layer override, I have the following entry for the Red Primary Protection CT. Similar entries for all the other layers as needed.
Wire Layer Name : Red Primary Protection CT
Wire Number Format: A%N
Starting Wire Sequence:10
Wire Number Suffix List: <left blank>
Now all I do is hit the tool to automatically number wires and it goes through and numbers everything as I require.
I do however, double check and adjust as needed due to limitations in the software.
The attached jpg shows an output for an overcurrent CT.
Regards Brad
Brad Coleman, Electrical Draftsman
