I created both 32 and 64-bit network deployments of ACADE 2009. Both installers finished successfully. When I try to run the deployment or even try to modify it, I get this error:
Failed to load C:\Users\\AppData\Local\Temp\_AIA.tmp\AcadeUIRes.dll
If I try to manually copy the file into the location and rerun the deployment installer, the same thing occurs as it wipes the folder clean before repopulating it. Setting the read only attribute on the dll doesn't help either.
Inventor and AutoCAD mechanical (32 and 64-bit) deployments work fine.
Is there a workaround or hotfix for this?
Vista 64 Enterprise is the OS if you didn't catch the user path. The deployment is on a Windows 2008 server.
