AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
2006 BOM sorting
3 REPLIES 3
jmburge
219 Views, 3 Replies
2006 BOM sorting
In ACE 2006, I am finding that my item numbers don't sort correctly on a panel report. See attached drawing for example.
3 REPLIES 3
in reply to: jmburge
I'm afraid this is a known issue and has to do with the text justification.
As a workaround you can try using right-justified for this field.
Pat Murnen
wrote in message news:5098154@discussion.autodesk.com...
...You could go to the Panel Config and enter 01 as the Item Numbering
Start.
This way it will sort correctly
Omar
"Pat Murnen (Autodesk)" wrote in message
news:5098187@discussion.autodesk.com...
Pat Murnen
jmburge
Omar, you can also change the justification to "Right" for the item field. See attachment for example.
”Boost
