AutoCAD Electrical General Discussion
Distinguished Contributor
10 Kudos
Post 1 of 3
2 source arrows from 1 wire, possible?
155 Views, 2 Replies
02-07-2013 02:51 PM
Hey guys,
I have a drawing (sheet 1) where I have 1 wire with a source arrow heading to sheet 2, the same wire on sheet 1 has a branch coming off it with a source arrow heading to sheet 3.
At the moment the source/destination cross refs between sheet 1 and sheet 2 are correct but the second source arrow on sheet 1 says it is going to the same destination as the other destination arrow on sheet 2 instead of sheet 3.
Is it possible to make these show up correctly or do I need to edit the text manualy?
Thanks!
192 Kudos
Post 2 of 3
Re: 2 source arrows from 1 wire, possible?
02-07-2013 04:11 PM in reply to: Tee.Dee
Yes it is possible. The only restriction I know off is that you can NOT have multiple sources going to one destination.
Check the signal code on each source arrow and make sure that they are different.
Edit both destination arrows and point them to the correct source arrows.
After that, while in the dwg with the source arrows, click on the tool to UPDATE the signal references.
Choose the option to pick the signals you want to update and then click on the two source arrows.
If that doesn't work, the next easiest solution would be to delete both sources and their destinations and then redo them, one source/destination pair at a time.
Regards Brad
Icemanau (NNTP handle: Brad Coleman)
10 Kudos
Post 3 of 3
02-07-2013 04:23 PM in reply to: Icemanau
Thanks Brad,
Im an idiot, I had the 2 source arrows named the same thing.... Been looking at these drawings for way to long!
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
