I have many wire layers on in my drawing. Currently, they are named with the guage and color...an example would be "16AWG_RED" or "14AWG_BLU". When I number the wires, I would like to just use the color and number, not the guage. I'm not sure how to do this. In the wire layer setup, I have added the color in the "Wire Color" column as "RED" for all red wires, etc. I also typed the color in the "USER1" column. I do not understand how to insert either the "Wire Color" column or the "USER1" variables into the wire numbering format.
I would like the wire number to come out like "RED 3" or "BLU 24" as an example. I have tried making the wire number format "%1 %N" and "%C %N" but I assume neither one of these are valid variables.
Hi Showlesscraig,
Try "%C %S" to get your "Red 3", or "Red 24" format.
Here is what you can use inside of the "Create/Edit Wire Layers":
%C - Colour
%S - Wire Size (Gauge)
%1 - User Var # 1
%2 - User Var # 2
%3 - User Var # 3
%4 - User Var # 4
%5 - User Var # 5
I hope this helps,
James
