Looking for help with a title block issue. Currently the title block will not insert all the lines in there correct place as was setup. If possible, how can this be realigned? The fields don't seem to fix the problem no matter what they are changed to. See attached items for reference.
Solved by jseefdrumr. Go to Solution.
Check your Title Block setup. It may have been corrupted depending on the method you used.
From looking at your screen shots, you used the WDT file for the setup as there is no sign of a WD_TB attribute in the title block.
Regards Brad
Brad Coleman, Electrical Draftsman
Thanks, that worked. Just too bad it only fixes 1 drawing and not the entire project. I have to go through every drawing and redefine the block. At least the template is fixed so no more problem in the future.
Thanks again.
The block is in the .dwt file. I had to pull it out as a single block for that. I just stumbled onto another problem though. After updating the block, I ran the title block update and it won't change anything when run project wide. But if I run the update on a single drawing it works. Any ideas as to why that is happening? I have closed ACADE to try and fix the problem.
Did you manage to solve this. I am having the same issue. For the active sheet the title block updates fine however the other sheets in the set have their alignments moved and thrown around. I believe its a font style issue however have not yet found a fix.
Let me know if you have any more info.
Thanks.
Sorry but how do I check what fonts I have. I was able to select the font in AutoCAD. It is Tahoma.
No I believe they are all there. The font is in the drop down and there are no yellow markers.
Its odd that they are all the same text but only some get moved. It keeps the drawing number and title lines perfect however really struggles with the date and serial number section.
I have attached 2 drawings to show how they are being moevd about. If you clickon each bit of text and reslect the alignment in text preferences it puts it where it should be and ATTSYNC works but I have to do this every time for every sheet.
Any Assitance is really appreciates. For now I am running an LISP file in the project utility to attsync each sheet at the end of the project.
Thank you.
Thats currently what I have running.
If I find the solution I will post it.
Thanks for your time.
