I am using the WD_BOMPNLR API call to generate a panel bom and dump it to a CSV file. It appears that even though I have a user post process (Concatenate DESC1-DESC3) lisp defined in the SET file the API call is not calling it. Can anyone else confirm this? It does work if I run a panel BOM report manually so I know the SET file is working.
Solved by drew_dewit. Go to Solution.
Turns out it was an issue with my post-process LISP. It was only getting info from the database for the schematic components and not panel components so most were getting ignored when concatenating DESC1-DESC2
