Does anyone else have a problem where ACADE closes with no notice and no opportunity to save work. This problem seems to only occur once per day maximum but seems to always occur at least once after I do a new boot of my PC.
I get no ACADE error message but when I reopen the application it gives me a chance to restore whatever it has from a backup file using Drawing Recovery Manager. It I made no unsaved edits ACADE acts like no failure occurred.
When I go to Windows Event Manager I see an error related to ucrtbase.dll module. After a Google search I found a knowledge link for this dll for Inventor. It states that I need to update my video card. Ironically enough it is the update of the Dell laptop driver to the latest video driver that has probably started causing this problem. Maybe this means I will be forced to go to version 2023 to fix it? Since my other team members also use version 2022 I would like to avoid an immediate upgrade.
Anyone else dealt with this issue?
In both 2022-2023... Set GFXDX12 variable to 0 (that's a zero) then restart that program, see if that helps.
If not, then start a support ticket through your subscription portal as explained here https://knowledge.autodesk.com/customer-service/account-management/users-software/support-options#:~....
Unfortunately, it crashed again, but this time it did give me an error message.
I am hoping that at the end of my current project my team will move up to version 2023 and it might help. Otherwise what you are saying is what may ultimately occur.
