I have a problem that the terminal strips look right in the terminal editor but when inserting to the drawing overlap eachother as per screenshots.
Solved by james.mcmillanNYR6A. Go to Solution.
this generally happens when your terminal drawing is not in the correct orientation, it must be drawn horizontal
if this is the case try deleting all the terminals in the drawing and purge all blocks
Its a custom terminal I orignally drew it vertical but then changed it to horrizontal. Worked ok in the terminal editor but then inserted it into the drawing and it placed them all ontop of eachother as per the screenshot. How do I purge all blocks?
type purge
i usually just purge all but you might want to retain layers so purge checked for blocks
