Hi David,
The same problem exists with the similar terminal strip in the WDDEMO on page 9. The strip has Phoenix UKK3 terminals with the same issue. I looked at the blocks and it seems that the content developers traced the wipeout region incorrectly. You have to tweak the supplied terminal symbols anyway. They have the TERM attribute in the middle of the symbol, right over the geometry. I move them out to the edge where they would actually appear in the real world. The panel symbols come from the manufacturers. But I think a content developer runs a script to insert the attributes, based upon the insertion point for the symbol. I'm not sure how they insert the wipeout region, but it must be automated as well, given that it doesn't match the outline of the actual block.
I tried correcting the one in the WDDEMO but the TSE spaces them according to the overall width. Perhaps some from Autodesk will have a better answer.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
