Hi, good afternoom. I´m usinfAutocad Electrical student version and I got a problem.
I`ve been trying to insert a ladder but not matter if it is before or after a save the drawing I can not enter the reference number for the ladder, the 1st reference edit box is deactivated,
Any clue that help me to solve and restore it, I really appreciate it.
Best Regards.
Luis
Solved by Icemanau. Go to Solution.
More than likely, your dwg is set to use the X-Y grid or the X Zone cross referencing.
Go to your DWG PROPERTIES -> Drawing Format tab
In the Format Referencing section, select the Reference Numbers
Now try to insert a ladder and see if the 1st Reference box is available...
Regards Brad
Brad Coleman, Electrical Draftsman
