Hi community,
Perhaps someone knows how to write different catalog numbers for plugs and jackets. In AutoCAD, it only allows writing one catalog number per item. However, plugs and jackets have different catalog numbers. For example, the male catalog number for PHOENIX CONTACT is HC-BB46-I-PT-M, and the female catalog number is C-BB46-I-PT-F. Maybe need to use separate for the plug and jacket of elements, but that look illogical.
Solved by james.mcmillanNYR6A. Go to Solution.
Do you talk about this? The component report look crazy 😄 I want what will be one TAGNAME and two component PLUG female and male
you can add further parts to the catalog of a component using mutliple catalog or assembly code
try the multicat option then see your report
if you didn't know this and are just starting to use, it might be worth looking up the use of multicat / assycode and choosing a route to follow that suits you best
it not help to me. I want have report like this
If have part which have one item. It is all okay, but if part make from more items than one is problem. Now I am trying to find solution.
there are many report options, try the bom report in tallied purchase list format or a component report
