I am using AutoCAD Electrical 2024. Only 2 dots are shown while drawing wires. After inserting wire, the first mouse click show only 2 dots and second click the wire will show. how can I set up to show the wire line on the first click.
Solved by rhesusminus. Go to Solution.
This sounds like a problem with the graphics driver.
Type 3DCONFIG on the command line, and turn off hardware acceleration in the dialog that appears.
Then try again.
Will it work better now?
You should update the driver for your graphics card so that you can turn on hardware acceleration again.
