I have just been tasked with setting up a few template drawings that our company will use when doing projects that require the IEC symbols. Can someone point me to literature that has tips or guidlines for going metric and using IEC symbols?
Any help is gratefully appreciated.
Scott
Solved by dougmcalexander. Go to Solution.
Hello Scott,
In AutoCAD Electrical, there is a default IEC standard project IECDEMO and IEC60617DEMO, you can check the project settings and drawing settings for the default project.
If you don't have the Project in your AutoCAD Electrical, please go to the Control Panel and change AutoCAD Electrical, add the IEC projects from the Add and Remove option.
Robin Shou
Quality Assurance
Autodesk AutoCAD Electrical
Hi Scott,
You will generally want to use an A3 (297x420mm) or A4 (210x297mm) size drawing environment. You could plot to fit an ANSI-B size. You could also use the Modify Symbol Library utility to scale one of the IEC libraries to inches by scaling at 0.03937 scale factor. This would make it possible to design on an 11x17 inch paper size with metric symbols, without the need to scale on insert. The scale on insert doesn't affect dots, angled tees, etc.; called features in the software.
I have seen customers attempt to use the Feature Scale Multiplier (FSM) in drawing properties to try to scale from metric to English or vice versa. It is best to avoid this approach because it can cause undesirable issues with respect to crossreferencing and tagging. I usually tell people who attend my training that the FSM should be used to scale up or down a small bit; a gentle nudge. I recommend not to scale up by more than two, or scale down by less than 0.5. If you find the need to scale beyond those ranges, it is best to scale the entire symbol library with the Modify Symbol Library utility.
The 3-phase buses and neutral are generally drawn horizontally across the drawings. But the main power usually starts at the lower left of the power distribution page, works its way straight up, through switchgear, and then turns right to go horizontal. Source/destination arrows will pass the potential from page to page. Single-phase power buses (i.e. control voltage) is drawn with the hot bus running horizontally across the top of a page and the common/return running across the bottom.
It is customary to break the schematic up by placing one control device per drawing. For example, a PLC input, an inverter drive, etc.
The IEC library that is included with AutoCAD Electrical tags with a one-letter code, based on IEC61346-2. The IEC60617 library, included with AutoCAD Electrical, tags with the optional two-letter code, based upon the option tables in IEC81346-2. You may wish to check with your customer to determine whether or not they prefer the one-letter or two-letter tags.
There are specific IEC safety directives that should be adhered to. A primary directive for industrial control systems would be IEC60204, the Machinery Directive. You may also reference EN60204, which is the European "harmonized" version of this standard. Basically it is a slightly modified version of IEC60204, as a result of meetings among various members of the European community.
Pay close attention to wire colors. They are different than North America. As of April 1, 2006, they are using Brown, Black, and Gray for L1, L2, L3, respectively, when identifying a wire potential by color. Light Blue is neutral. Red is AC control voltage that is less than mains, phase-to-phase voltage. DC positive is Brown, DC common is Blue, and DC negative is Gray. Foreign or Unknown voltage is orange. Ground is 50% green and 50% yellow (+/- 20% of either). These are just a few to get you started; check the IEC standards for additional details.
I started in the controls industry in Germany, before IEC. But the DIN standards and the British standards became the basis of the IEC standard, which made for an easy transition for me. I have converted numerous North American companies to the IEC standard, so they can ship their systems to Europe and other parts of the world where IEC has become the standard. The on-site workflow-based training course I teach is available for either the JIC/NFPA or IEC standard. We design the same control panel in either course, so the attendees get to see the same control panel designed with each standard. They can compare to the two for future reference. The only difference between the two designs is the U.S. voltage of 480VAC versus the European voltage of 400VAC.
I was right where you are back in 1991, when the company I worked for in Germany was bought by a U.S. company and I was tasked with converting the U.S. team over to the DIN/IEC standards, so their equipment could be accepted globally. I like the IEC standard more than the U.S. standards. Once you get accustomed to it, you realize just how helpful the documentation is for troubleshooting.
It is my 1st time to use AutoCAD electrical, i installed it, and added the liberary of IEC but i can't find it while using the program, i tried to search for the liberary while creating the new project but didnt find anythn as well, how can i find the IEC??
the problem is that i can't find the IEC Demo and cant find any files of IEC
Doug,
I attended one of your classes in Atlanta last year. From what i remember, there is a command that will allow me to update all of my schematic symbols from the JIC symbol to an IEC symbol. Am i correct in my interpretation? If so, can you please tell me what the command is?
