AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Find/Edit/Replace Crashes
2 REPLIES 2
374 Views, 2 Replies
Using Find/Edit/Replace crashes AutoCAD whenever I uses the "Replace All" button.
Replacing instances individually works fine.
I'm running ACADE 2010 SP1 on Win 7 x64.
Any suggestions (other than repair/reinstall)?
2 REPLIES 2
dougmcalexander
Hopefully someone from Autodesk can address this. I ran the 64-bit version of AcadE 2009 just fine, but Vista crashed during a training, which I was conducting. It turned aout to be an incompatibility of 64-bit Vista and the HP laptop it came on. I abandoned HP and Vista it and went back to trusty Win XP Pro on an IBM Thinkpad. I have had no problems since. I've have never had an issue with F/E/R in any version though. But this 64-bit technology is still going through the debug stages. I don't trust it yet for my important work. Perhaps someone at Autodesk can help you out with regard to Win 7.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
robbm2k
in reply to: dougmcalexander
did anyone hear if this was something that is a local setting/compatibility issue? I'm running ACADE2013 with Windows 7 64bit and am getting a crash from it as well every single time...
”Boost
