I have been doing Field Wiring diagrams fro several years now manually. Is there a way to automate this process within ACADE? It is very time consuming when done manually. Mind you, it is much better than having to do the actual wiring because the contract electrician couldn't read the schematic, but it would be nice to have some tools that would automate the process. Thoughts, suggestions, ideas all welcome. Thanks in advance!
A bit of explanation of the attached image. I will use a Layout Tab and view ports to have the terminal blocks viewed. I then manually draw all of the devices, wires, etc. It is very dumb and must be updated manually with any changes to the schematics.
you mean something like this ? no automated method to do hook up drawings currently exist
