I guess you have created the component "HGV1" of your own. You will need to
have the following naming convention in order to have a correct symbol
created:
1st Char as 'H' for Horizontal and 'V' for Vertical
Next 2 Chars as for Family name
4th Char as '1' for Parent and '2' for Child
5th Char as '1' for NO and '2' for NC
All other characters are as User defined.
From HGV1 as symbol name, you did not allocate the 5th Char hence it throw
an error exception.
Please modify the name for the "HVG1" symbol to "HGV11" and try to insert it
again. The problem should resolved. Let me know if you still get the error.
Thanks.
Best regards,
Richard
wrote in message
news:6240673@discussion.autodesk.com...
Hi
When I try to insert a component with AE2010, I get this error
Specify insertion point:
Error: bad argument value: positive 0_.UNDO Current settings: Auto = On,
Control = All, Combine = Yes, Layer = Yes
Enter the number of operations to undo or [Auto/Control/BEgin/End/Mark/Back]
<1>: _END
It is only on a specific component. I did a lot of tests with the databases
and symbols.
The first time the error happened was when I put the symbole HGV1 in the
same folder as HGV1001.
I deleted HGV1, but I still get the error. The symbol is on the screen, but
I can't edit it. I can copy the symbol and then edit the copied symbol
(weird)
What can I do?
