I would link know, if are there any place where I can to do download of the blocks for AutoCAD Electrical, For the example; Plc, Motor, Motor starts, etc...
If anybody knows, could share with me, please?
Solved by TRLitsey. Go to Solution.
Hi there,
I am not clear as to the context of your question. Do you have any version of AutoCAD Electrical? The standard blocks come bundled with the software. Or are you looking for something custom? Or do you have some other CAD system and are looking for the AutoCAD versions?
Thank you
I need to blocks PLC, MS, etc.. dimensional. I looked in sites of the manufacturing, EATON, Siemens, etc... however I not found.
I understand that AutoCAD Electrical have to a library installed. However, I need something custom to assemble my panel.
Hi there,
I have not tried this but my co-worker across the way is recommending you give this a try as a starting point. I don’t know if they are intelligent symbols or just blocks but it may be a resource for you. Your question specifically, I don’t know of anywhere except the software package that has the intelligent AutoCAD Electrical symbols.
http://www.draftsperson.net/index.php?title=Electrical_Symbols_-_Free_AutoCAD_Blocks
For Allen-Bradley you can try this, you type in the full part number, relays, starters, servos etc. It will open a window with documents for that part. Very offten you will find 2D CAD drawings and sometimes 3D STEP files.
http://www.rockwellautomation.com/support/selection.page
Please mark this as a solution if it works for you (the button at the bottom of this post), kudos are always welcome.
Thank you – Good luck
