Use the Footprint Database File Editor. Choose the manufacturer of the enclosure. If the part number already exists in the database, you simply edit the record and set the block field to look for your version of the enclosure.
Hint: If you have a block that includes multiple blocks inside of it (i.e. front door, sub-panel, sides, etc.), place an asterisk (*) at the beginning of the block path and the software will explode the block into separate blocks when you insert it. You may notice that many of the enclosure blocks that are included work this way. It's an old AutoCAD trick.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
