It would be very helpful if the sight distance checking tool saved the settings (layers and hatch pattern for the sight distance analysis lines) in the drawing.
Also, it appears there's an error in how sightlines are checked when using an offset eye path. When one programs in an offset eye path, the tool does not use the surface elevations at the offset for doing the checking. While it draws the sightlines at the correct offsets, it uses the surface elevations from the selected alignment.
Jeffrey Rivers
Win 10 Pro 64-bit, Intel i9 3.7GHz, 64 GB
NVIDIA RTX A4000
C3D 2020 V13.2.89.0
