From corridor sections exists a "view/edit corridor section" and you can watch the sections full screen, comfortably changing stations:
http://www.youtube.com/watch?v=zBpyVmXh3sY
But the surface sections, generated with a sample lines group, we can only show them with "multiple section views" to represent graphically them in the same drawing and print them.
I would like a tool bar for select the station and view the surface sections.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
