There needs to be a way to set Vault to only save 1 version (or however many
versions you want) of each drawing. As it is now it saves 5 versions which
means you need to have 5 times the amount of server space. I know that you
can manually purge the Vault or you could write a script to do it at the
command line each night but It doesn't seem like it would be that hard to
have an option where you tell it how many versions you want it to save.
Jason
