AutoCAD Civil 3D Wishes
Active Contributor
lhampton
Message 1 of 4 (180 Views)
Survey Figure's Imported as 2d Poly's
180 Views, 3 Replies
06-28-2012 01:47 PM
A large amount of surveyors are having trouble with your guys "Survey Figures" they are proving to be very un-intuitive and hard to use. Rather than go into the VERY lengthy list of things wrong/unfunctioning with your Survey Figures, please consider adding a pass-through for Surveyors' that want old functionality back. This pass-through would still incorporate the desc. key stuff but instead only spit out 2d polylines instead of Survey Figures.
I know there's about 10 of you that are reading this that want to make a big long shpeal about how much better C3D is because of this or that, please just save it. I use C3D and am aware of its (many) shortfalls in the survey functionality, this is a simple request coming from me and the 25 other survey engineers that I work with that are having trouble with these Survey Figures. We do pay you guys around $20k a year to use this software, we have a right to be heard.
Intel i7 2600 /z68 Gigabyte
8gigs DDR3 1800
Intel 320 Series SSD
Quadro 600 (1gig)
C3D 2013 / LDT 2009 / Win7 x64
Active Contributor
lhampton
Message 2 of 4 (152 Views)
Re: Survey Figure's Imported as 2d Poly's
07-17-2012 11:13 AM in reply to: lhampton
Bump
8gigs DDR3 1800
Quadro 600 (1gig)
Distinguished Contributor
nmessina
Message 3 of 4 (127 Views)
08-02-2012 08:45 AM in reply to: lhampton
I agree we never draw our Survey's in 3D, its just way to cumbersome dealing with 3D curves.  Also it causes problems with our engineering/drafting department, when they need to use our linework to create hatches, to extend and trim lines when they are in 3d.
Nicholas, Messina Jr.
Valued Mentor
TerryDotson
Message 4 of 4 (123 Views)
08-02-2012 12:08 PM in reply to: lhampton
You can of course hold out in hopes this will come to be.  But if you were to consider an option that is available now take a look at the Point AutoDraw functionality in MapWorks Points, a low cost add-on.  You can use AECC Points to generate LwPolys and graded 3dPolys at the same time (on separate layers) and more.
