I would like the generate figure command to have a maximum length option for segments. That way if the points collected do not have the correct (or forgotten to add) descriptor, like BEG or END, you will not have segments running all over your map.
Such as, if most points are collected every 100 feet, you would not have linework with 1000 foot segments. it would remove or not draw that segment.
thanks
Randy
