AutoCAD Civil 3D Wishes (Read Only)
Solid Corridor Model
5 REPLIES 5
mathewkol
458 Views, 5 Replies
The labs has the solids from corridor but that's not what I mean. I love corridors, don't get me wrong. I just think they can be even better and if we can get this wish answered I think we can solve many of the problems currently faced by users.
Take Revit Arch for a moment. Draw a wall then add a window or door to that wall. Revit knows the wall must be broken in a certain way to accomodate that door. Imagine a corridor with that functionality. Start with a "Road" defined with some parameters, say 2 lanes, curb, sidewalk, and daylight. Add a "driveway letdown" object. C3D would know exactly how to break the road to accomodate it. Give us grips so we can adjust the width and start-stop stations easily. Give us a fully featured set os possible parameters for these objects.
Other type of objects wculd be:
Medians
Landscape areas
Among others.
If two roads intersect, C3D would know how to deal with the intersection, similar to how AIM works right now.
Corridors are good but I can't really use it for printing due to various things: no curved feature lines being one of them. I must maintain dumb non-dynamic linework.
Having a fully capable "solid model" which is a finished model like a building would alleviate many workarounds and would give us a really cool way to design.
Thanks.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
5 REPLIES 5
in reply to: mathewkol
We're starting to think Civil 3D is going nowhere, and we might try out Revit + Siteworks.  It handles solids, and provides a full BIM model.  Plus MEP can handle water mains, and we could actually share models with the architects.
That's in theory.  How well it might work is another matter.
Although I'm definitely feeling your frustrations with Civil 3D (and I'm saying this as a Civil 3D certified professional), you should check out the documentation for Landxml and IFCxml to get a taste of exactly what each one documenting.  They serve separate needs.
In other words, I'm not sure how Revit will work for railway spirals, defining catchment areas, etc...
Ideally, Civil 3D should have support for solids, and should be able to translate Landxml pipes into equivalent IFCxml pipes and import .
Promoting Civil 3D as a “BIM” solution for civil engineers is a mistake on Autodesk’s part, because it raises certain expectations.  Civil 3D is not BIM, however, maybe we should start using terms such as Civil Information Modeling or Construction Information modeling.  I’m writing this with the Landxml schema in mind.
There has to be better workflow between Revit and Civil 3D; maybe object enablers? If I can view non-dwg files, such as GIS data via data-connect in Civil 3D, there should be way for Civil 3D and Revit to connect and view each other directly and not through a third *.adsk file, maybe with proxy objects.  Not quite xrefs, but then I’m not going to xref edit a building shell or doorway.  Why pdf’s, dwf’s, dgn’s, but not rvt’s?  There has to be a way; if Navisworks can do it, then so should Civil 3D and Revit.  Just as I can use data connect to access particular GIS data from different files, I should be able to access only a building shell, or pipe connection from a rvt file if I so chose, without having to ask the architect to create a adsk file every time there is a design change. And if there absolutely has to be a third file format, then it should automatically apply design changes, such as VSP3D files which link Civil 3D to 3ds Max Design.
Profile hatches are poor representations of 3D solids and once again are CAD-like, not BIM-like.  The same can be said for section views; material hatches, using shape styles is not the same as a virtual material.
Maybe a solution is a new Landxml schema that has solid materials? A tin/grid solid with its points defined by x, y, z1 (top elevation), x, y, z2 (datum elevation)?
mathewkol
I didn't want this to turn into a BIM debate or what other software I can use. I just wanted to extend the suggestion that a solid corridor-type of object would be a cool addition. I appreciate the thoughts, but maybe we can keep on track and keep the comments limiyed to the subject at hand.
Matt Kolberg
tcorey
Matt, I have been envisioning a corridor similarly, one where you could plug in various constructs like driveways, wheelchair ramps, etc.
I don't know that you would have to be able to insert solids, but have the ability to insert a construct you have designed as a corridor. You could model a driveway as a corridor and then plug it in where needed.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
mathewkol
True. It doesn't really need to be a solid as long as you could plus in these types of things easily.
Matt Kolberg
