Say I have a 5 mile road that has the CL being designed with multiple alignments, segmented into 1 mile streatches for example.
Maybe it’s broken up to represent different phases, different designers, or just breaking it up for performance issues.
It would be so much easier if Plan Production allowed you to select this type of multiple alignment situation to run a single set of view frames down.
In addition, it would seamlessly transition from one profile to another - even if the stationing started back at 0+00 for each alignment.
This kind of functionality would allow for fewer sheets, easier sheet layout, easier match-line editing, etc.
The CL alignments are all related, but currently PP only allows you to run a set of view frames down a single alignment.
I could understand not applying to alignments that are going opposite directions from each other.
-Bruce
