AutoCAD Civil 3D Wishes (Read Only)
Quick Elevation Editor
2 REPLIES 2
Jeff_M
419 Views, 2 Replies
I wish that this command would honor the Pickfirst selection. Now when a Featureline is selected and the Context menu is shown, selecting the QuickElevationEditor starts the command, but if the command was last used with a F/L in a different site than the one the selected F/L is in then you are left wondering why the command isn't letting you edit the F/L you had started with. Enterimg S, then choosing a site will change the site but often I'm not sure which site I'm currently looking for. This command should auto-switch to the Site which holds the selected F/L.
2 REPLIES 2
andrewpuller3811
in reply to: Jeff_M
Yes, I find this behaviour in a few civil 3d commands and it is quite painful as it is not the expected behaviour for a command in autocad.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
sboon
in reply to: Jeff_M
+1 in support of this request
Steve
Expert Elite Alumnus
