Please fix the following Survey Database Bugs...
I have discovered a few Survey Toolspace commands that should be fixed, as I believe they are bugs. The bugs specifically have to do with handling of existing SURVEY points that are referenced in FBK files, such as STN (Occupy point) and BS (Backsight point) command lines. When deleting, re-importing, resetting or removing points from the Survey Toolspace in either Import Events or Networks command they should not be deleting points that were existing prior in the Point Database.
When deleting, re-importing, resetting or removing points it should only affect points created by observation commands such as, “F1 VA“or “NEZ“ within the Network or FBK file.
STN 165 5.250 "5"
BS 181 0.00000
PRISM 4.880
F1 VA 1000 0.00020 259.057 89.57330 "CK 181"
PRISM 5.000
F1 VA 1001 179.59580 203.415 90.02380 "CK 161"
F1 VA 1002 193.47250 209.626 90.01190 "81"
F1 VA 1003 196.19230 214.342 90.01130 "81"
This is a bug in 2012 as well. It's really annoying. I know it wan't an issue in 2010, I don't know about 2011. I've submitted a bug report to Autodesk but it was not resolved. I was left with the impression that they don't feel like it is a problem.
