AutoCAD Civil 3D Wishes (Read Only)
Pipe lateral ovals on Structures
3 REPLIES 3
mspatz
290 Views, 3 Replies
Description:
Showing the little oval on the pipe network structure where a lateral connects into a manhole or inlet.
How Used:
An inlet or manhole that has 3 pipes connecting to it in a "T" shape. If you profile the top of the "T". In LDT, Pipeworks will show an oval where the lateral connects into the inlet/manhole on the profile. Civil 3D DOES NOT! That needs to be addressed.
One step further:
While we are adding this issue, why don't we do one better! If the oval is on the backside of the inlet have it show with a hidden linetype; on the front side a solid linetype.
Feature Affinity:
Piping in Civil 3D 2006....or as far as I can tell 2007.
3 REPLIES 3
in reply to: mspatz
What also may be nice is to show all of the crossings.
I wrote a VBA for LDT that will insert the crossings in the profile. It is fairly involved but has saved us alot of time.
David Urban
mspatz
in reply to: mspatz
Crossings in Civil 3D are easy. Just use the Override style in the profile properties dialog. See http://civil3drocks.blogspot.com/2006/06/civil-3d-nuts-and-bolts-showing-and.html
With LDT you could always insert iterferences. Pipes-->Finsh Draft Profile-->Align/Run Interferences Message was edited by: mspatz
in reply to: mspatz
yeah but it doesnt work if part masking is involved
nor does it work when you want to show the end of a pipe that is not
crossing as an oval.
there are missing pieces for sure
(thanks for the blog post plug!)
Dana Breig Probert
wrote in message news:5336731@discussion.autodesk.com...
