Solved by Jeff_M. Go to Solution.
Solved by el_nath. Go to Solution.
A subject without content. Please explain, because what may be obvious to you is not so obvious to others, like myself, as I'm quite dense. What is an offset xref and what would you do with it?
IE9? I didn't realize that folks still use Internet Explorer as their default browser. That's very sad.
Maybe you should try installing Firefox 4 or Chrome, maybe even Opera. They're safer to use than IEx. Just a suggestion.
