AutoCAD Civil 3D Wishes (Read Only)
dulin75
435 Views, 2 Replies
layer filters
I have noticed that with styles comes a ton of layers and layer filters is the way to work through them.  However, is it possible to create a layer filter option on the ribbon so i don't have to open my layer properties manager every time I want to change filters?   Our Microstation users have this ability and just can't believe we don't!  Unless I am just missing something!
thanks
Shawn Dulin
Tags (2)
2 REPLIES 2
andrewpuller3811
in reply to: dulin75
That was one of the first things I added to the ribbon on our company cuix.
In the CUI, in the bottom left in the command list area, change the drop down that says "All Commands Only" to "Ribbon Control Elements", in the search box just above the drop down start typing "LayerFilterComboControl" when the command appears, drag it to the ribbon panel you want, or Quick Access Toolbar.
We use layer filters more than layer states so I move the layer states drop down below the slideout on the Home-Layers panel and put the LayerFilterComboControl in it's place.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
Can't get this to work
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
