AutoCAD Civil 3D Wishes (Read Only)
Message 1 of 1
Dave_Lovse
302 Views, 0 Replies
Label Map Check
I have been having a few issues with the Map Check function of both C3D 2012-2013. When I am selecting a straight line dim/distance  there have been no issues, but about half of the curve labels with radius/arc length come up with an error stating there is not enough data to perform the check, I then have to draw the cord line and copy the chord bearing into the mapcheck parameters. This is very time consuming, is there a fix for this? Also, in the future will there be an option within the mapcheck parameters to input tangent bearing or radial bearing for non-tangential curves?
Dave Hill
0 REPLIES 0
