AutoCAD Civil 3D Wishes (Read Only)
Integrate Hydraflow into Civil 3D
0 REPLIES 0
Message 1 of 1
fcernst
315 Views, 0 Replies
Please get the Hydraflow packages actually into Civil 3D with a menu of its own.
Not run as a parallel and disconnected application as it is now.
Look at the options we had in LDD off the Hydrology menu. We were able to work right inside LDD. We were able to graphically pick our Tc lengths and slopes, channel slopes, culvert inverts, basin areas, spillway crest elevations, etc.
i have attached a PDF with screenshots of some of the dialog boxes that allowed you to go into the drawing and select the data.
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
0 REPLIES 0
