AutoCAD Civil 3D Wishes (Read Only)
Flip label Justification instead of anchors
4 REPLIES 4
IanMcClain
1490 Views, 4 Replies
So now that cogo points have a seperate point label rotation (which is awesome) how about a "Flip Justification" for label components. The Flip Anchor doesn't seem to do anything for me since the text component always justifies either to one side or the other. If I want text to justify "away" from a node I have to have two styles of left and right justification. See attached example pic: I would prefer the labels rotated to the left side of a node to have left justified text and those right of a node right justified text.
Ian McClain
4 REPLIES 4
I did the attched with the "Stacked Text" option for the point labels.
Peter Funk
Autodesk, Inc.
Peter Funk
Autodesk, Inc.
I've tried that, but I lose my underline component.
Ian McClain
To get it close, you could underline the elevation text. This won't be perfect, the line won't be exactly in the center and there will be a slight stagger between the line and the leader (on my printer at 1:40 it was the width of the line).
Peter Funk
Autodesk, Inc.
Peter Funk
Autodesk, Inc.
el_nath
in reply to: peterfunkautodesk
I'd like to bring this wish up again.
I wish for 3 states of flip anchors with text.
0: False, anchors 123456789 remain 123456789
1: True, anchors 123456789 become 987654321
2: Justification only, anchors 123456789 become 321654987
I thought of vertical flip as well, but I can't imagine what use it would be. Justification flip, however, would be great.
Nathan Selles-Alvarez, P.E.
Senior Civil Engineer
