Currently, when you find a drawing in Windows Explorer and double click on drawing Autodesk DWG Launcher the Laucher seem to open the drawing in the last version of AutoCAD that was open. I would like to see the Autodesk DWG Launcher recognize the drawing various format automatically open the drawing in correct version of Autocad to match the drawing format.
Now if you dont have the curent file format Autocad installed then it will prompt you which version of AutoCAD to use, such as if a Drawing was created in AutoCAD 2006 and you have AutoCAD 2009 and 2010 installed, you will be prompted as to which version of AutoCAD to open. Vice Versa, say you double click on a AutoCAD 2010 format file and only have AutoCAD 2008 and 2009 installed then the DWG Launcher will notify the user of the incompatible file format and prompt the user and open the file in TrueView 2010 for a conversion to a usable file format,
Nicholas, Messina Jr., PSM
