AutoCAD Civil 3D Wishes (Read Only)
don´t sincronyze right Material of modeled.
0 REPLIES 0
Message 1 of 1
joantopo
811 Views, 0 Replies
If you change the material of modeled form surface in properties corridor, this materal appears right in properties surface.
But if you change the material of modeled in a properties surface, it doesn´t change in a properties corridor.
For example:
properties surface, I change the material of modeled, new material: "Acondicionamiento del terreno..."
But in the properties corridor, for the same surface, doesn´t change the material:
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
0 REPLIES 0
