Sharing an object requires several steps, set working folder, set current project, create the shortcut, and add a reference. An easy process for sure but one that doesn't come without its potential problems.
I'm looking for this:
A new command DREF that behaves similar to XREF. You are prompted to select a DWG then you're presented with a list of all of the sharaible objects within that DWG. You select, say, a surface then the program performs all of the necessary steps from my first paragraph behind the scenes, creates the shortcut and adds it to the Prospector's shortcut list, and adds the reference to the current file all in one step without needeing to even set the current project first.
What do you think? The underlying technology doesn't need to change; this routine simply automates the process, especially not having to open the source fike and create that shortcut manually. That file could be unweildy and if you don't have to open it, so much the better.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
