AutoCAD Civil 3D Wishes
Distinguished Contributor
bruce.jordan
Message 1 of 4 (292 Views)
Create Survey Point Group using Query Capabilities
292 Views, 3 Replies
04-30-2010 09:56 AM
Unless I'm missing something, the only way to add points to a Survey Point Group in the Survey Database is to manually check each point # you want. Looks like it's still this way in 2011.
It would be such a time saver if the Survey Point Group worked like the Point Group on prospector tab with the ability to query points based on point numbers, description, etc.
-Bruce
nmessina
Message 2 of 4 (292 Views)
Re: Create Survey Point Group using Query Capabilities
05-02-2010 07:49 PM in reply to: bruce.jordan
I would love to see the Survey Point Group Manager to be exactly like the Cogo Point Manager. The code exists, why didn't Autodesk make them the same?/
Nicholas, Messina Jr.
cbaildon001
Message 3 of 4 (235 Views)
10-27-2010 05:36 PM in reply to: bruce.jordan
It works exactly like Point Groups in Prospector, actually you make the point group in Prospector first.
Create the Survey Point Group and click the 'pick' icon at the top of the window and then select by Group on the command line. You can then select the point group you made in Propector.
The downside is that the points must be in the drawing?
I aggre that the same functionality should be in the Survey Toolspace.
Caleb
Caleb Baildon
Surveyor
Opus International Consultants Ltd
Greymouth, New Zealand
Civil3D 2015 - Windows7 64bit
bruce.jordan
Message 4 of 4 (227 Views)
10-28-2010 10:41 AM in reply to: cbaildon001
Hmm, interesting.
I don't get any points added to a Survey Point Group when clicking the "pick" icon.  Doesn't matter if I choose All, Numbers, Group, or Selection.
-Bruce
