Holy Moly! How do you figure these things out? I would have never
thought to do this since there are Surface elevation labels specifically
for this task.
OK, thanks a lot Tom. Works for me. I will have to recreate my elevation
label styles, but no big deal.
David Dixon
Clark Nexsen, Architecture & Engineering
Civil 3D 2007 SP2
Dell Optiplex GX620
XP Pro SP2, Intel P4 3.4 Ghz, 2 GB RAM
256 ATI Radeon X600 Dual Display
http://dca2civil3d.blogspot.com
On Thu, 21 Sep 2006 16:31:19 -0400, Tom Berning wrote:
> David,
> If you use the general note with reference text, you can create a spot
> elevation label. Then if you want to change surfaces, select all your
> labels and change the referenced surface in the properties window. This
> is how I have my style setup.
