Is there something that was added to 2012 that you could calculate a bounded volume between surfaces? I could easily do it in terramodel, but cannot find a simple solution in Civil 3D
I know it is in the analyze pulldown, but you cannot find a BOUNDED volume between two surfaces. It is always between a surface and a datum of zero.
Create a volume surface and then use the bounded volumes on that surface. A volume surface compares two surfaces together.
