AutoCAD Civil 3D Wishes (Read Only)
Add to Point Group
7 REPLIES 7
Message 1 of 8
386 Views, 7 Replies
Add to Point Group
This is right click function on a point
object I have missed dearly from LDD.
I am reminded every time I get field work to add to
an EG model.
A Remove from Pouint Group would be nice as
well.
John
7 REPLIES 7
Message 2 of 8
Hidden_Brain
i posted here a few weeks ago about how i can make a point group current, so that even after the pint groups are created, if i add new points, they will automatically go to the current point group instead of ALL POINTS group. i did not know that right click on a point object gives you the option "ADD TO GROUP"! that would solve some of my problems!
Message 3 of 8
Hi youngEIT,
All points go to the All points group.
They can also be in as many other groups as you care to assign them too.
Laurie Comerford
Message 4 of 8
Civil3DReminders
If you don't mind doing some beta testing and are using 2010 try this download out:
http://style.civil3dreminders.com/C3DRemindersPack.dll
You'll have to add it to the right click customization in the cui though. The command is AddPointToPointGroup, not quite sure what the command should be for the right click. Use Netload to load the dll.
Message 5 of 8
Thanks Christopher!
I will give it a shot & let you know how it goes.
John Mayo, PE
Core i7 920 6GB DDR3
GeForce GTS 250 1 GB
Vista64
Message 6 of 8
Civil3DReminders
If anyone is interested most of the code that's in the dll may be found in this post:
http://blog.civil3dreminders.com/2009/05/add-point-to-point-group-part-i.html
The file has been updated and improved and is at the same link:
Message 7 of 8
...and it works very nicely.
John
If
post:
Message 8 of 8
Civil3DReminders
Here's a better link:
http://style.civil3dreminders.com/civil3dreminderspack
