AutoCAD Civil 3D Wishes
New Member
ddeaner
Message 1 of 2 (69 Views)
Ability to save & import/export your XREFed annotation should it be detached.
69 Views, 1 Replies
12-08-2011 11:19 AM
As you are aware, you can label text on top of an XREF.  If you unload the XREF and then reload, all of your annotation will reappear; awesome.  Problem comes in when someone detaches the XREF and then tries to reattach. All of the annotation is gone.
I would like a routine similar to LMAN (that saves layer states as .LAY files) that would allow a user to re-import their annotation should another user detach the XREF.   If this capability existed in C3D, it would greatly help our production processes, especially when we annotate C3D Parcels.  Data Shortcuts can't be used on Parcels (and Points).  We would like to trust that the annotation that is created on the XREF's (final maps, tentative maps, engineering exhibits, etc.) would remain in the drawing with both the Unload and Detach options and/or have the ability to export and import a "snapshot" so that the annotation could be returned should the XREF accidentally get detached.
el_nath
Message 2 of 2 (62 Views)
Re: Ability to save & import/export your XREFed annotation should it be deta
12-08-2011 11:59 AM in reply to: ddeaner
Have you tried using (creating) a survey database to manage parcels instead of xref's?
Nathan Selles-Alvarez, P.E.
Senior Civil Engineer
