AutoCAD Civil 3D Wishes
Valued Contributor
tony1978
Message 1 of 9 (2,455 Views)
2013 wish
2455 Views, 8 Replies
08-25-2011 01:43 PM
  1. vertical curved pipes in profiles (water)
  2. button on ribbon to set one slope for a whole pipe network or selection (i dont want a lisp or vba routine)
  3. need water structure parts -specialy for profiles.
  4. table for line and curves combined
  5. catchment feature still needs more work
  6. water lowering feature for on profiles so it automatic created pvi's and angles (water)
  7. velocity and depth of flow in pipe properties.
tony
CAD Manager/Senior Design Tech
www.tonyscivil3dworld.blogspot.com
robert.thomson
Message 2 of 9 (2,266 Views)
Re: 2013 wish
10-18-2011 10:15 AM in reply to: tony1978
Tony, have you seen or have a  routine to do #2?  I could really use that.
1. One other thing I'd like is the ability to connect separate pipe networks as we often break into an existing system with a new one.
2.  Also forcemain pipes and parts such as Air Release Valves.
3. Ability for 64 bit version to connect to ESRI File Geodatabases (32 bit can do it apparently).
Product Support
Jason.Hickey
Message 3 of 9 (2,198 Views)
Re: 2013 wish
11-01-2011 11:29 AM in reply to: robert.thomson
The abillty (or lack thereof) to connect to any ESRI data in a 64 bit environment is a limitation forced upon us by ESRI. ESRI needs to create the 64 bit providers in order for this to happen.
Jason Hickey
Premium Services Specialist
New Member
GingerGuru
Message 4 of 9 (1,894 Views)
Re: 2013 wish
01-11-2012 09:16 AM in reply to: tony1978
Hey Tony,
We have been making several pipe networks in our projects that being 'existing' and 'proposed' and were not able to connect the networks together.  However, and I haven't tried this, but it was suggested that we use one network Ii.e for sanitary) but create 'existing' and 'proposed' symbology for the network items.  One network, different symbols.  May accoplish what you are trying to do.
Active Member
focusengineering
Message 5 of 9 (1,660 Views)
Re: 2013 wish
02-01-2012 07:58 AM in reply to: tony1978
Line labels that can label the Cartesian Coordinates "North" "South" "East" & "West" for the bearing.
Valued Contributor
RobR88
Message 6 of 9 (1,577 Views)
Re: 2013 wish
02-07-2012 01:10 PM in reply to: tony1978
I definitely second the need water structure parts -specialy for profiles.
BANI_INDICA
Message 7 of 9 (1,309 Views)
Re: 2013 wish
03-04-2012 05:04 AM in reply to: tony1978
IN CROSS SECTION VIEW
 AS THE CIVIL3D HAS OPTIONS TO LABEL & CREATE BAND FOR OFFSET AND ELEVATION FOR DIFFERENT SURFACES IN THE SECTION VIEW IT ALSO SHOLD HAVE
   1 OPTIONS TO LABEL THE COORDINATES AT EACH SEGMENTS
   2 IN THE BAND ALSO THERE SHOULD BE POSSIBLITY TO GIVE ORDINATES OF EACH SEGMENTS.
THESE OPTIONS ARE ALREADY AVAILABLE WITH MX ROAD I HAVE SEEN. BUT CIVIL 3D LACKING...
IM NOT SURE  ! IF INFORMATION IS WRONG ! SORRY !
oceanside
Message 8 of 9 (1,162 Views)
Re: 2013 wish
03-13-2012 06:38 AM in reply to: tony1978
#3 YES...YES....  Need several parts added to Catalog such as tees, wyes, hydrants, laterals, etc.
the best is at the beach!
Member
ChrisRS
Message 9 of 9 (651 Views)
Re: 2013 wish
06-03-2012 01:21 AM in reply to: oceanside
A very (very, very, very) modest start on Pressure Pipes is included in CD 2013. It includes some push on gate valves but no other apprutenances. I guess we can wait for more.
