maybe a Median and Ditch Inlet? or just a Grate inlet (without the curb piece)?
Selecting Neenah Foundry in the Inlet Manufacturer drop down box will give access to inlets available from Neenah including yard inlets.
yes, say - R-4400 could be used as Yard Inlet, but under the "Inlet type" it is only "Combination Inlet" option - do you think it is acceptable?
If I understand correctly, when a Neenah inlet is selected the Inlet Type is grayed out because the software uses performances tables fron Neenah rather than calculations to determine capture.
