Civil 3D Forum
xml error on import
1 REPLY 1
Joe-Bouza
246 Views, 1 Reply
xml error on import
I read a few older threads and I only have 2 pipes max at any structure and I added an outfall just to see if that would help but it just doesn't seem to like the xml file. Is this expected for 2008?
Your Name
Your Name
1 REPLY 1
Matt.Anderson
in reply to: Joe-Bouza
Joe -
Research your flow direction of your pipe network.  There can only be ONE pipe leaving a structure.  With LandXML you can research the structures, but occasionally Civil 3d will flip the pipe slope with a negative one LandXML export instead of flipping the pipes to and from.
Matthew Anderson, PE CFM
Product Manager
Autodesk (Innovyze)
Rail Community
